Slow hydraulics
I have a couple of trucks where the sideshifts are moving veeeerrrrrryyyy slow. Aux system is only running about 975 - 1000 psi (should be almost 1800). The lift/aux pump is less than a year old and the solenoid valve isn't the cause either. Anyone have ANY ideas? We're fresh out.
  • Posted 14 Jun 2009 02:10
  • By jeff_i
  • joined 2 Nov'08 - 15 messages
  • Iowa, United States
yep...
cylinder bypass would be my first w.a.g....
I would also be considering changing hydraulic oil and filters... as a preventive maintenance.
freezer operation?
  • Posted 20 Jun 2009 22:26
  • Modified 20 Jun 2009 22:28 by poster
new pump fixed that particular problem. we have another one, same model, that shifts one direction ok under load but not the other. cylinder bypassing?
  • Posted 20 Jun 2009 21:11
  • By jeff_i
try lifting and sideshift at same time,if it sideshifts,reach or tilts faster, that means the pump isnt running fast enough,the aux side of pump is bad
  • Posted 17 Jun 2009 13:22
  • By 537man
  • joined 17 Jun'09 - 1 message
