toyota speed control
Can a toy 8fgcu25 be slowed down in travel speed what is involved? Any help greatly appreciated
  • Posted 3 Jun 2009 11:05
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
there are several versions off this truck the cheap one No you must make with another parts to fix it But when there is A analyser mounted on the right side off the littel display you can make choice for speed up and down.
When you lift over 1.80 Meters the truck slows down but there you can make chance's
  • Posted 20 Jun 2009 18:02
  • By johngen
  • NB, Netherlands
Toyota do supply a speed control device, it consists of a fly by wire throttle control and wheel speed sensor. So you can adjust max speed with out loosing torque for climbing slopes. lots of $. The bolt under the pedal is a good idea. One step better is to adjust the air velocity governor on the carb. Only negative about both of these methods is you also loose engine RPM's for lifting!
  • Posted 19 Jun 2009 01:33
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
What type of system does your 8 series have?
  • Posted 18 Jun 2009 09:09
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Don't take this the wrong way, but............what about a bolt under the foot pedal to stop full throttle.....simple and cheap......just an idea
  • Posted 17 Jun 2009 22:47
  • By Prentice
No Is a series 8 propane I have a customer that wants his truck slowed down.He has a hoge poge of trucks and this is the 1 I cant slow down.
  • Posted 3 Jun 2009 21:31
  • By proshadetree
Hi Poshadetree
If I understand you rite you are talking about a toy remote control toyota, if so you could cut the feed to the motor and fit a voltage regulator in line with it at a voltge lower than the battery e.g. if the battery is 8 Volts fit a 4 Volt voltage regulator and it will go at half speed (but the power will also have half the power to go up slopes). Hope this helps.
Shane
  • Posted 3 Jun 2009 18:49
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
JCB 533-105
UN Forklift FD15-18T
GemOne
Lee Rushton Lee Rushton
