starts and goes directly into shut down
need help! i went on no run ,call the unit starts and goes into 30sec shutdown.let set couple minutes does same starts and shuts down but if as soon as it shuts down I try to start I get 3
interlocks hyd,seat,return to neutral,the strange thing is no codes.I'm thinking vsm any help and advice would be appreciated.and I would like to get a copy of fault codes @ trouble shooting for vx trucks
Thanks Smoken
  • Posted 7 May 2009 13:48
  • By smoken
  • joined 16 Nov'08 - 10 messages
  • Indiana, United States
smoken
There are over 3000 fault codes. The manual is 1400 pages. You need to contact your local dealer and purchase the manual.
  • Posted 19 Aug 2016 02:21
  • By BREWSKI
Hey Man, I have previously had the same issue. crank the truck and it immediately goes into engine shutdown. there is a sensor on the radiator without enough coolant the engine goes into shutdown.
  • Posted 19 Aug 2016 01:51
  • By Jeff33McGee
  • joined 19 Aug'16 - 1 message
-Jeff
quality product! happy days.
  • Posted 18 May 2009 06:18
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
tugmaster. i had that fault this very week on one of our own brand trucks. dodgy rear light replaced and update of vsm. sorted
  • Posted 16 May 2009 02:10
  • By kevin_k
check your lights are working.check the wipers work.if they dont the truck considers this a safety issue and shuts the truck down.
  • Posted 16 May 2009 01:08
  • By tugmaster
  • United Kingdom
scroll the up/down buttons on the dash.if it on 30 sec shutdown it should give you a reason
  • Posted 9 May 2009 03:14
  • By kevin_k
just a w.a.g.; key switch. bad contact on "run" position? shuts off fuel? that would explain "no code".
  • Posted 7 May 2009 20:40
Toyota 8FGU25
Flesherton, Ontario, Canada
Manitou M50-4
edition #1245 - 28 August 2025
In this week’s Forkliftaction News , we look at MHEDA’s Q3 Economic Advisory Report which reveals current resilience in the US materials handling sector... Continue reading
Tampa, United States
Tampa/Orlando Florida, United States
Dallas, TX or Lexington, KY, United States
Marietta, United States
Lift Tek Elecar
ASSET FINANCE
Nov 2025
Lift Tek Elecar
The word "okay" (or its abbreviation "OK") originated as a humorous misspelling. In the 1830s, a fad in Boston involved using abbreviations of intentionally misspelled phrases. "OK" stood for "oll korrect," a playful mispronunciation of "all correct".
