Toyota 7FGCU25 no power to fuel regulator
S/N 87985 truck will not start and I do not get battery voltage to fuel shutoff on lp regulator.
  • Posted 6 May 2009 23:25
  • By truckparts123
  • joined 11 Oct'08 - 16 messages
  • New Hampshire, United States
It was a broken wire at the green plug by the distributor. Thanks for all the help gang!
  • Posted 23 Dec 2009 10:06
  • By troy_m
hey troy it should be right near the fuse box
  • Posted 20 Dec 2009 07:10
  • By rich_k
  • joined 30 Oct'07 - 108 messages
I'm not a Toyota guy -where is the fuel solenoid relay? I'm going there on Sunday night to see if I can make sense of the wiring a bit more.
  • Posted 20 Dec 2009 04:15
  • By troy_m
Then check signal generator in the distributor Rich
  • Posted 20 Dec 2009 02:50
  • By rich_k
Check signal to the solenoid first (relay) Then
  • Posted 20 Dec 2009 02:47
  • By rich_k
edit
  • Posted 20 Dec 2009 02:20
  • Modified 8 Jan 2010 13:54 by poster
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
I'm having the exact same problem with a 7-series lpg truck. I supply power to the lower solenoid coil and the engine will start and idle but no acceleration. The engine light flashes 9 times if that helps. Any ideas??
  • Posted 20 Dec 2009 01:46
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Are you checking the voltage with the wires connected to the shut off solenoid??? If so you might have a short in the coil shut off solenoid. I replaced one last week. runs great
  • Posted 11 May 2009 22:14
  • By Prentice
If relay is ok check signal from signal generator inside the distributor if no signal then replace signal generator and rotor, Rich
  • Posted 9 May 2009 07:58
  • By rich_k
1. Please check the distributor. Take off the upper cover. Inside you can see 3 parts the multiplier, the electronic card and the sensor. The sensor some times is bended out so it is not very close to the rotating part and this provokes instability to the open-close action. Using a scewdriver bend this sensor closer to the rotating part (If you have the distributor out you can turn it using your hand. If the sensor is at the right distance from the rotating part you can fill the magnet that tries to stop the rotation). This problem happens in Toyota 7series often.
2. I dont know if the gas regulator you have is working in compination with the distributor. In 7series I have found two types of gas regulator. Both have two electronic valves on them. In the first case both valves work with the key on (so you can provide + and - using 2 cables from your battery directly to test if the regulator works properly or is a malfanction of the wiring). In the second case the small valve is activated ONLY when the starter/ignition is activated and the big one is activated with the key on and stays on during the truck is working.
3. Check also the water supply through the regulator of gas. Sometimes dirt is collected inside the regulator and the water cannot pass so the gas cannot evaporate.
Thats all I know. Good luck
  • Posted 9 May 2009 07:36
  • By livanios_s
  • joined 3 Feb'09 - 5 messages
  • Attiki, Greece
It is LP gas. I checked the wires at the distributor and they seem o.k. I also swapped the relay with the ignition one. The power wire to the fuel solenoid will light a test light dimly whenever the key is on and does not go bright even when cranking. I believe the signal comes from the distributor through a rev sw to the fuel relay?
  • Posted 8 May 2009 21:43
  • By truckparts123
If it's the type I'm thinking of you'll only get a 12v feed to the cut off solenoid when cranking, you'll not get it by just turning on the ignition switch and checking for a live. Trace the wire (black and white I think???) back down under the left hand step to the relays and fuse box.
Have you got a little more info on it?
  • Posted 8 May 2009 08:09
  • By FLTdotCOdotUK
  • joined 28 Jun'08 - 21 messages
  • Tyne & Wear, United Kingdom
Please write more about the probem. I dont get it. Is your truck gasoline/lpg ? Is there a fuel cut off valve? Do you check if enough fuel comes to carbirator?
  • Posted 8 May 2009 06:17
  • By livanios_s
  • Attiki, Greece
GemOne
