Mystery Clark everything good but no drive
spent a lot of time on this clark EC500-40, E355-68-1572.
now get to a point that panel is good tested on bench. new pot.
manually pushed in A1 with either fwd or rev, drive ok
when use pedal, fwd/rev contactors sucked in but no drive.
does anyone have any ideas?
  • Posted 2 May 2009 11:57
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
do you have circuit diagram for this folklift? i need i so bad for the problem on steering pump. thank you
  • Posted 23 Mar 2023 13:17
  • By NIKOLA_SRBU
  • joined 23 Mar'23 - 1 message
  • Michigan, United States
ns
Is the small 1/4 amp fuse blown?
  • Posted 3 May 2009 03:56
  • By Truck_Tech
  • United States
#29 to panel has no volt. (contactor in or not)
  • Posted 3 May 2009 03:48
  • By hellokitty
What voltage do you have on wire #29 going to the control card? It should read about 4 to 5 VDC and slowly go to 0 VDC when the accelerator is depressed.
  • Posted 3 May 2009 03:06
  • By Truck_Tech
  • United States
wire from pot to controller already been checked. and meanwhile contactors do *** in but just no drive.
  • Posted 3 May 2009 02:57
  • By hellokitty
negative comes through the recs or controllers (the chopper panel), the wire from the pot to the controller may be the problem
  • Posted 3 May 2009 02:40
when A1 pushed in maunally, it drives.
since A1 is negative, it seems to me the drive motor is missing a negative, what would cause this.
  • Posted 3 May 2009 02:34
  • By hellokitty
Sounds like either a faulty accelerator pot circuit,or a faulty SCR control card.
  • Posted 3 May 2009 01:24
  • By Truck_Tech
  • United States
tech,
when key on, steer pump on, contactor *** in, don't notice SCR any hum.
  • Posted 2 May 2009 23:48
  • By hellokitty
Do you have any SCR hum, when the directional contactors close?
  • Posted 2 May 2009 23:26
  • By Truck_Tech
  • United States
Unicarriers FHGE35T5S
UN Forklift FGL25T
Deborah Baker Deborah Baker
UN Forklift FGL25T
