Pulling Waukesha out of C500-40 Ser 355
I'm removing the Waukesha engine from a C500 Ser355 for a friend.
Where is the inspection hole to remove bolts in flexplate?
It's been years and I can't remember where it was so I thought before I show up and **** around for half hour looking I'd ask. Help me look good guys!
Troy
  • Posted 1 Mar 2009 02:23
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Actually, engine is out and the there are no flexplate bolts to take out so the starter could have stayed in. I took the top inspection plate off the trans and had a good peek in there anyways. The torque convertor came off with the flex pate and wasn't a big deal. I did have to remove the counterweight and lift the overhead guard a few inches but in the end it was a breeze and took just over 4 hours (with a bit of a mess on the floor ;)). The old guy still has it!
  • Posted 9 Mar 2009 21:59
  • By troy_m
Indeed remove starter first.
Doc
  • Posted 9 Mar 2009 12:56
  • By Drlifttruck
  • joined 20 Nov'05 - 106 messages
Lift Trucks all the same, just painted different colors.
Doc
Email: kulsh@forkliftservice.net
Hey Prentice -what part of Ont are you from? I cover London and surrounding area.
  • Posted 3 Mar 2009 11:46
  • By troy_m
C500 Clarks.........great units when running, but you have to take half the machine apart to repair anything. Good luck
  • Posted 2 Mar 2009 23:25
  • By Prentice
-that's too bad -it's buried under the rhs master cyl. More crap to take off I guess! thanks
  • Posted 2 Mar 2009 03:48
  • By troy_m
I think you get at them right thru the starter hole.
  • Posted 1 Mar 2009 03:58
