how do i pull the fault codes
Just found this forum and it is great. Cool to see people who enjoy dealing with forklifts.
So I'm having this problem: Have an older e40 xl-27 Hyster SN:c108v.. does not have a display to show codes and when I went to hook up the ev100lx handheld tester, the plug was incorrct for the card. The plug is very similar but the slots are spaced differant. There must be a system older than the LX. How do you retrieve the codes? I was working for a cat dealer in the 80s and must have missed something UH.
  • Posted 27 Feb 2009 14:34
  • By rrlift
  • joined 27 Feb'09 - 22 messages
  • Illinois, United States
Working so I can ride.
does that old chariot not have a sevcon panel. why do you need to pull codes ,whats the problem mate
  • Posted 1 Mar 2009 19:35
  • By kevin_k
it should fit
the plug is the "Y" plug
the larger of the two sized plugs
the 1st large plug to the right of the terminal board
usually has less wires
they go in this order
A - B TB Y Z when you have the card situated as you can read the part number
also make sure no one replaced the Y plug on the handset with a Z plug
the keys are spaced differently and wont work for each other
other than that my handset always works
the SX series uses the same LX handset with a different plug style (PY)
  • Posted 28 Feb 2009 04:46
  • Modified 28 Feb 2009 04:47 by poster
  • By justinm
Big Joe PDR30-154
USD7,500
Toyota 8FG25
