Kalmar CQD 25 (1990)
Anyone know which is correct brake fluid for Kalmar?
TVH wheel cylinder says use correct fluid (mineral) but yet all master cylinders appear to be for brake fluid.
I would expect mineral oil to break down seals, am I wrong??
  • Posted 13 Feb 2009 05:47
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
dot 3or 4 used on these old dogs. i would change both wheel cylinders. guarenteed the other side will go shortly.
  • Posted 17 Feb 2009 04:01
  • By kevin_k
thanks for your replies, reason i asked is that i fit new m/cyl early dec and now 1 wheel cyl has started leaking. It may just be coincidence, but i filled it back up with brake fluid.
when i ordered new cylinder from tvh there was warning about correct fluid.
I think the cylinders are correct because there is only 1 that measures up (1" bore) but I also started looking at master cylinders on tvh and noticed that all kalmar m/cyls list brake fluid.
dont want to fit new wheel cyl and that to go belly up in another 2 months!!!
things like that get you a bad name quickly (and cost you money)
  • Posted 16 Feb 2009 04:03
  • By ian_h
  • United Kingdom
I am fairly sure the that Kalmar have never made any small machines. The ones bearing their name are just badged up machines from other manufactures. Which will usually be either Climax or TCM both of which would use normal brake fluid. It may pay to check if TVH have sent you the correct part.
  • Posted 15 Feb 2009 21:41
  • By AndyPandy
i used to work on those trucks a few years back and always used standard dot 3 brake fluid. now a days though there are many cylinders that use mineral based oils,so be a bit careful.Always read maintainance where you can
  • Posted 15 Feb 2009 18:56
  • By bruce_k
  • joined 10 Mar'08 - 15 messages
  • devon, United Kingdom
well ducks some master cylinders do use mineral oil different seals that will not be damaged ie swelling i am not sure on your truck any chance of taking a sample from wheel cylinders
  • Posted 13 Feb 2009 10:34
  • By towmotor
  • joined 19 Feb'07 - 360 messages
TCM FD115-3
Unicarriers FD80-2
VETTER Industrie GmbH
