Bogs out
bogs out in the morning when motor is cold. I noticed it wont run if the carb is uncocoverd. Original problem started when it ran out of propane, It also backfired. all vacum line are good.
  • Posted 24 Jan 2009 02:33
  • By albert_h
  • joined 22 Aug'06 - 59 messages
Thanks guys for the help...problem solved. Turns out the spark plug wires were the cause of troubles. Thanks again!
  • Posted 5 Feb 2009 03:14
  • By albert_h
We have replace the fuel lock and the regulator/vaporizer and the mixer. but problems still persist. On a rapid start it seems sluggish like it bogs out also back fires once in a while. This forklift has a dual system for running regular gas and lpg, we're currently using the lpg system.
  • Posted 28 Jan 2009 03:40
  • By albert_h
o-ring in the coupling?
  • Posted 27 Jan 2009 00:04
  • By justinm
may need a new diaphragm in the LPG carb.
  • Posted 24 Jan 2009 11:04
