NO AUXILIARY FUNTIONS
I NEED AID WITH THIS MACHINE SINCE SYSTEM CARD DOES NOT SEND SIGNAL BY THE PS10 TOWARDS THE SELENOID, REPLACE CONTINUOUS SYSTEM CARD AND WITHOUT VOLTAGE
EZ-A-02-24376
EASI DR30TT
  • Posted 5 Jan 2009 10:38
  • By jose_m
  • joined 5 Jan'09 - 13 messages
  • d.n, Dominican Republic
Jose, can you put your email in your profile
Do you hear the pump run when you push reach or tilt?
If you hear pump react, but no aux functions, you may have a broken overmast cable
  • Posted 14 Jan 2016 13:27
  • Modified 14 Jan 2016 13:30 by poster
  • By EasiTek
I HAVE A EASI WITH THE SAME PROBLEM. HAS STEERING
BUT NO REACH ,TILT.SIDE SHIFT.
NOT GETTING VOLT TO THE HYD MANIFOLDS SOLENOIDS
THANKS FOR ANY HELP
  • Posted 7 Jan 2016 09:20
  • By studog
  • joined 8 Oct'10 - 12 messages
fuse in the filter assembly was the issue
if that fuse goes you lose aux functions
filter assembly is an option and is not found in all trucks
  • Posted 13 Jan 2009 13:52
  • Modified 13 Jan 2009 13:53 by poster
  • By justinm
Libiao Robotics
UN Forklift FD40T
Manitou MH25-4
