Hyster 120XM LPG 4.3 Governor
The lift starts and idles perfect, when you push the throttle the engine only revs up just enough to notice then backs down. If I operate the throttle at the governor it revs fine. The governor is no longer available new I can find them used for a pretty penny I just wanted to see if anyone else has had this issue and if they found the governor at fault. Thank you.
  • Posted 22 Jul 2025 01:35
  • By Jason_Kinzer
  • joined 22 Jul'25 - 1 message
  • WA, United States
Jason,
Had the same problem 4.3. Customer had the engine rebuilt only to have no acceleration. Found governor had failed. This was on a 80XM. Not sure what the difference, we quoted replacement to the customer. Good Luck
  • Posted 12 Sep 2025 06:02
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
