Century converters
Hi,
Can anyone please let me know does a Century 2335 B converter with electric regulator use the original tachometric relay?
My understanding is it would need it for the initial 3 second power to prime but not during running, which would mean a different relay that would only send initial power not crank/run power.
Any info would be great thanks.
  • Posted 13 Jul 2025 18:31
  • By MicD
  • joined 28 Sep'18 - 14 messages
MicD
I work on lift trucks 40 years the electric primer button is there if you need to prime it for a blast of propane but if the machine is running good it will most likely start most people installed a button on the dash if they needed to prime it for hard start in the morning. You could use the start circuit on the starter as it cranks it would prime the carb and when it starts the start circuit is off wire a relay if it does not have a R post on the starter. Good luck.
  • Posted 16 Jul 2025 03:24
  • By Scott_
  • joined 16 May'21 - 316 messages
Scott
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
