serial no E098N0266H
Hi all
Hyster with a Pyroban system cutting out on drive motor temperature.
Motor checks out ok.
Appreciate your help
  • Posted 21 May 2025 06:54
  • By Paddyteclinde
  • joined 3 Dec'21 - 32 messages
  • Ireland
How is the motor sealed?? Is it in a full enclosure or just the brush gear in an enclosure?? Who checked the motor is?? Have you stripped and cleaned it?? The resin I'm asking us because Enclosed motors can run hot dye to carbon build up causing earth faults and if it has been stripped is the enclosure OK??
  • Posted 25 May 2025 22:38
  • By lifter01
  • joined 4 Jul'09 - 463 messages
