Forklift not turning on
Hi, guys. Sorry for my bad english.
I am a owner of Jungheinrich EJC212 2008 year and couple days ago I try to turn it on and a put the code in the forklift and i just frest 3. numbers blinked and i didn't wont to turn on. So does anyone have a idea to what could the problem be. Tenks in advance.
  • Posted 9 Apr 2025 22:04
  • By Petar_Corluka
  • joined 9 Apr'25 - 3 messages
  • Bosnia And Herzegovina
Petar Corluka
Also check the battery and it's connector
  • Posted 10 Apr 2025 08:16
  • By Syed
  • joined 14 May'15 - 195 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
1-2-3 são opções de velocidade do equipamento pre ajustado, para ligar vc deve inserir código de 4 digito por ex: 2580.
  • Posted 10 Apr 2025 08:02
  • By edmar_p
  • joined 18 Jan'13 - 49 messages
  • Guarulhos SP, Brazil
Edmar
When self-testing does not pass, the contactor does not turn on, there is no need to mislead people.
There is probably an emergency switch there, it would also hurt to check it
  • Posted 10 Apr 2025 07:52
  • By pavel_y
  • joined 27 Jan'16 - 52 messages
  • Donetsk region, Ukraine
Specialized repair of electrical equipment warehouse. Repair of controllers and components
Ok now I'm understand, you should follow the instruction by Mr. Tanel_M.
  • Posted 10 Apr 2025 07:36
  • By Syed
  • Sindh, Pakistan
Yes there is a keypad with numbers 1-9 and when I need to turn on the forklift i need to put in a 4 digit code.
  • Posted 10 Apr 2025 07:22
  • By Petar_Corluka
Petar Corluka
You mean there is a keypad on the truck where you put the 3 digit code to switch on the truck?
  • Posted 10 Apr 2025 07:12
  • By Syed
  • Sindh, Pakistan
I doesn't show show error code. When i try to put turn it on on pad with numbers , number 1, 2 and 3 have a small light underneath them and when i put in the code (to turn ond the forklift) the small lights blink in order: small light under 1 then under number 2 and then under number 3.
  • Posted 10 Apr 2025 06:39
  • By Petar_Corluka
Petar Corluka
What are the 3 numbers on the screen? Most likely it is an error code.
  • Posted 10 Apr 2025 06:29
  • By Alexey_Potekhin
  • joined 20 Dec'24 - 9 messages
  • Russian Federation
It fails self test, check for incoming voltages from battery, before and after contactor.
  • Posted 10 Apr 2025 04:24
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
