Boom Lift 2 Speed Issues
I have a 2001 660SJC track boom lift that is having two speed issues. It is the machine that has a steel tracked excavator undercarriage instead of wheels. Runs great in lower speed but doesnt want to go into 2 speed. It will sometimes surge like it goes into 2 speed for a second and then kicks out for a second and back and forth. If I unplug the level sensor it will go into two speed but then it thinks its off level so the boom operates very slow. We tried a new level sensor as it had been leaking but that didn't make any difference. We also checked the position sensors on the boom but they all seem good. Trying to to figure out were the issue is. It seems like it must be a poor connection somewere. TIA
  • Posted 26 Mar 2025 01:18
  • By Tyler_Warkentin
  • joined 26 Mar'25 - 2 messages
Verify all limit switches first...if one isn't working correctly will not show code will just stay slow
  • Posted 11 Apr 2025 14:36
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
If u haven't yet go on Jlg.com and download the service manual...buy an analyzer to help with troubleshooting...then verify u have power and ground to high speed coil...if so..download parts manual and try to find another valve that has same part #...swap valves and see if it then works...is so order new valve..if not...u missed something..could be in joystick or box but analyzer will verify that
  • Posted 11 Apr 2025 14:34
  • By Matthew_Reed
UN Forklift FBT20NQZ1
Unicarriers FHGE35T5S
Oxford Ct, United States
Esie Cortez Esie Cortez
