No start, no service manual
My employer bought this pallet jack, knowing that it needed repair. After charging the battery, it fails to power up when I turn on the power switch and input the key code. I am trying to get a service manual from Toyota so that I can diagnose the problem, but the Toyota support site just runs me around in circles, and never leads me to where I can download the service manual. How do I find a service manual?
  • Posted 13 Nov 2024 07:10
  • By Stuart_Nuss
  • joined 13 Nov'24 - 3 messages
  • Illinois, United States
Stuart Nuss
Those are known for bad key pads and broken harnesses in the handle. Watch out for TVH replacement harnesses. Sometimes the wires are wrong and blow the key pads.
  • Posted 8 Feb 2025 12:03
  • By Fritzthecat
  • joined 20 Oct'23 - 23 messages
  • Connecticut, United States
Be nice to forky
Touchpad itself may be bad...upon startup hold down horn button to see if options show on display...do not let go of horn button until it says e..then post the errors
  • Posted 24 Dec 2024 04:56
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
I now have a manual. Following the wiring diagram, I seem to have power going to the components, and all the fuses check ok, but the keypad does not light up, even though it has power and ground connections. I did replace the controller, since that is what the seller said was supposed to be the problem, but nothing changed. I suspect that there is an issue with the keypad/handle controls but am not certain how to verify that.
  • Posted 19 Dec 2024 05:59
  • By Stuart_Nuss
Stuart Nuss
If you can email me..I can walk you through the repair..[email address removed]
  • Posted 17 Nov 2024 17:08
  • By Matthew_Reed
Does the green led light up when code is entered? Try 1258
  • Posted 14 Nov 2024 05:06
  • Modified 14 Nov 2024 05:06 by poster
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
Nothing lights up, horn doesn't work. I input 1 and the green button, which is supposed to be the basic code to start it.
  • Posted 14 Nov 2024 05:00
  • By Stuart_Nuss
Stuart Nuss
What code are you putting in? do the led's on the key pad light?
  • Posted 13 Nov 2024 09:49
  • By andrew_k
UN Forklift FBRS15KQZ2
SMV (Konecranes) 4632CC5
