temperature sensor wiring
hi can anyone help me i have a etv c16 ge100 650dz with serial number 91009217 i have a issue with it driving very slow and comes up with temperature warning does anyone know which are the 2 wires that go to the temp sensor and where is the temp sensor located?. i'm hoping to solder in a resister to bypass the temp sensor many thanks in advance
  • Posted 12 Nov 2024 20:44
  • By james_thomas
  • joined 12 Nov'24 - 2 messages
  • United Kingdom
j thomas
Hi many thanks for taking the time to respond to my post it's much appreciated. I'm hoping to get time to look at it today so will let you know the outcome
  • Posted 18 Nov 2024 20:16
  • By james_thomas
  • United Kingdom
j thomas
If you remove the seat, there should be 2 inside hecxscrews that can be loosened with allen key, then you can remove the hood. There are actually separate drives for lift and travel, make sure you get the right one. Temp sensors are embedded in the motors swinding so usually it is a 2 pin plug with blue/red white/red wiring or white white.but also make sure the motor is not running hot -there may be a problem with brake or gearbox.
  • Posted 17 Nov 2024 02:13
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Esie Cortez Esie Cortez
