digital display on dash
I had an employee that was pushing buttons on the panel and I can't get the temperature gauge back up on display. On display is the speed in the left hand top corner and the hours on the right hand bottom corner. Any ideas how to get back to it? We are having overheating issues with it and want to make sure we keep an eye out before it gets hot. Thank you
  • Posted 25 Sep 2024 23:26
  • By Cory_Hinkle
  • joined 25 Sep'24 - 2 messages
  • Indiana, United States
Thank you I did disconnect the battery over night still popped up in this menu.
serial number is A967V01789J
  • Posted 8 Oct 2024 23:28
  • By Cory_Hinkle
Cory,
Not sure what display you have, each lift depending on the series will be different. Serial number will help. You can try disconnecting the battery for 30 seconds and see if it will reset display back to factory settings. If that does not work send serial number. Good Luck
  • Posted 1 Oct 2024 05:47
  • By Fishmech
  • Virginia, United States
Lift Tek Elecar
Oxford Ct, United States
