Crown WP-3000 - Code 853 only in forward
Hi All!
Had to replace the handle up/down microswitches and I'm now getting code 853 when I try to go forward. Works fine in reverse direction. I checked all the knuckle wires and fuses. Any ideas why this error only pops up when going forward? (Code pops right away when going forward.... never in reverse)
Thanks in advance!
  • Posted 25 Sep 2024 06:51
  • By Danny4592
  • joined 25 Sep'24 - 1 message
Danny
R&R Forward/Reverse pot, get with Crown dealer and get OE Parts. New OE kits come with a set of plastic bushings for the controls to ensure pot does not exceed limits. Make sure when you install test the repair by operating like an operator would and push/pull the throttle control as hard as you can. If you have access to the Curtis handheld you should clear the codes so you can see if the event code returns, if issue persists you may have to flash the new X10 handle software to the Access module through the Crown software if you have access or may have to call Crown in.
  • Posted 3 Oct 2024 13:50
  • By Pepsi_Fleet
  • joined 3 Oct'24 - 1 message
  • Kentucky, United States
Hello, if the error appeared after having made the repair, I would disassemble it again and check the position of the throttle potentiometer or if it has microswitches, check that they are not activated.
The error may be due to a potentiometer being out of range, which is not calibrated. You'll have to check that, as long as the error wasn't present before you took everything apart.
  • Posted 25 Sep 2024 20:09
  • By Pablo
  • joined 19 Apr'24 - 11 messages
  • Argentina
Technician
change forward reverse pot 853 code pot faulty
  • Posted 25 Sep 2024 19:40
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Elwell-Parker ESI500-36
Crown RR5225-30TT321
