Electric shift transmision trouble
Hyster S155XL2, Ser# C024V02936E. we have 4 of these machines and one has a electrically activated shift system which isn't working. It has a module #8530585 R2, you need to step on the brake to activate the shift circuit. There is a red LED on the module that is not on, it flashes when you key on, the power and ground circuits are tested and good, i can power the shift circuit by jumping the module plug power to the switch power terminal (term#2 - term#5). The brake lights work. The park brake start lockout system works. What I would really like is a wiring diagram, any help appreciated.
  • Posted 25 Sep 2024 01:23
  • By Torinoguy
  • joined 12 Sep'17 - 3 messages
Bob Blenkarn
Torino,
That module is an operator presence module. These modules are known to fail. Verify all connections and wires first. Also, make sure the alternator is charging at the correct voltage. Failing alternators have been known to cause all kinds of problems. Send email to fishmechatcoxdotnet. Good Luck
  • Posted 26 Sep 2024 02:05
  • By Fishmech
  • Virginia, United States
Elwell-Parker ESI500-36
Maxlion FB35LI
