Daño en avance
Agradezco la colaboración de todos. Tengo un problema con un estibador CROWN SX3200. El equipo avanza si muevo la perilla de acelerador aún y cuando el maneral se encuentra en posición de parking. Ya revise micro switch tanto de maneral como de hombre atrapado. Reemplace botón paro de emergencia y la falla persiste.
Plase use English language.
Littoral Translation
I appreciate everyone's collaboration. I have a problem with a CROWN SX3200 docker. The equipment moves forward if I move the accelerator **** even when the handle is in the park position. I already reviewed the micro switch both in the manner and as a trapped man. Replace emergency stop button and the fault persists.
  • Posted 20 Sep 2024 03:36
  • Modified 20 Sep 2024 19:20 by administrator
  • By Samir_Rom
  • joined 27 Mar'23 - 4 messages
  • Mexico
ING. Samir
Hello, you will have to check if the microswitch cables are not shorted elsewhere. I don't think it's the emergency stop button, since that button stops the entire machine.
Saludos
  • Posted 24 Sep 2024 22:35
  • Modified 26 Sep 2024 16:44 by administrator
  • By Pablo
  • joined 19 Apr'24 - 11 messages
  • Argentina
Technician
Taylor XC300M
New - Sale & Hire
SMV (Konecranes) 16-1200B
