service maintenance
we have a 2007 yale glp050zg that we are doing a complete service on. I'm working on a spread sheet for our mechanic so he will have all specs at his disposal.
I'm needing fluid type and capacities for engine, trans, gearbox, axles, hydraulic, coolant.
thanks
  • Posted 12 Sep 2024 00:20
  • By harrison98
  • joined 12 Sep'24 - 1 message
  • Wyoming, United States
Garrett Harrison
Harrison,
Each lift can vary depending on how the customer ordered. Below are the standard specs and fluids used on this lift. Steering is normally run off of the hydraulics. Good Luck
Engine 4.5 to 4.9 quarts 10w30
Hydraulic 36 to 37 quarts ISO 46
Anti-Freeze 11.6 Boron Free
Transmission 10 quarts J20C Fluid
Drive Axle 8 quarts 80w90 gear oil
  • Posted 18 Sep 2024 23:25
  • By Fishmech
  • Virginia, United States
Oxford Ct, United States
Libiao Robotics
