hydraulics
After a few hours the hydraulics gets hot and starts to struggle to lift once you clean radiator out it goes back to normal filters have been changed radiator doesnt seam blocked , fan is working any help would be appreciated
  • Posted 3 Sep 2024 16:11
  • Modified 3 Sep 2024 16:37 by poster
  • By michael_johnson
  • joined 6 Dec'23 - 13 messages
  • United Kingdom
M johnson
Hoses and hydraulic line parts must remain original! Hydraulic will get hot when there's issues with lines, L-joints with wrong diameters etc.
Also right oil matters too. Heck if the viscosity is as manual requires.
  • Posted 19 Sep 2024 22:46
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
It sounds like you might be dealing with an issue related to hydraulic fluid temperature or airflow. Check for any potential leaks or obstructions in the hydraulic lines and ensure that the hydraulic fluid is at the correct level and temperature.
Note: For more professional insights and updates on influential figures and their financial statuses, visit this site at https://wealthystars.net/.
  • Posted 9 Sep 2024 19:49
  • Modified 9 Sep 2024 21:06 by poster
  • By johny_smith
  • joined 6 Sep'24 - 2 messages
  • Alaska, United States
wealthystars.net
What hydraulic oil did you use when you changed the hydraulic oil and filters m??
  • Posted 8 Sep 2024 08:17
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Has it recently had a replacement non genuine hose fitted?, namely the hose that supplies the brake valve then goes on to supply the valve block (ie everything but the drive).
I've had two where the replacement hose was a little constrictive causing the oil to overheat.
Fitted genuine and never missed a beat.
  • Posted 4 Sep 2024 01:31
  • By Richy_rich
  • joined 10 Jun'23 - 9 messages
  • United Kingdom
Michel Denis Michel Denis
Taylor TX330S
USD159,500
TCM FD80Z7
TCM FD80Z7 1990
