Error code 125 & 126
I have a Crown SC 5200 that I am working on right now and it is throwing me a code of a 125 & 126. I followed the steps as on the crown website but continues to give me the same codes but only when I press the accelerator pedal. Before the code goes off everything else functions properly and you can here the relays click but as soon as I release the pedal and hit the accelerator pedal to move it codes out
  • Posted 21 Aug 2024 05:11
  • By JoshuaS
  • joined 21 Aug'24 - 1 message
  • Alaska, United States
It sounds like you have a CAN wiring issue or a bad fuse on one of the modules. Have you verified all the CAN wiring to each module making sure the reistance is right? Doing this could also tell you if one of the modules has a bad resistor causing the issues.
  • Posted 23 Aug 2024 01:05
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 223 messages
  • Wisconsin, United States
