ENG HAS AMISS ON #3 HAVE REPLACED WIRES AND PLUGS PULLED WIRE FROM INJECTOR
RUNS THE SAME SO CHANGED INJECTOR AND STILL THE SAME
S
SOMEONE ON THE FORUN SAID IT MIGHT BE ALIFTER PROBLEM
IF ANYBODY COULD HELP PLEASE DO
  • Posted 10 Apr 2024 08:50
  • By hdridermike
  • joined 5 May'18 - 24 messages
  • Kansas, United States
old guy
HD,
The problem will depend on the engine. PSI and GM engines were known for lifter problems. 2.4 GM was also known for electrical issues at the coils. PSI also had timing belt problems. Mazda engines were simple, but also reliable. I would swap coil from one cylinder to another and see if the miss moves. If not, suspect cylinder. Engine type and serial number would help. Thanks.
  • Posted 16 Apr 2024 22:26
  • By Fishmech
  • Virginia, United States
Kalmar DRF450-70C5XS
Enforcer FLBAXT25
