C9000 - 32781 front wheels will not move
Hello, working on A C9000 - S/N 32781
i could not get the front wheels to rotate when change direction. The rear tire moves fine every time. I went to the vale under your feet (there is two vale the one at the front) I can put power to the coil and make the front wheels change direction. So that tells me I am not getting power to that vale. Dose any know where power come from? I have all good fuse and relays.
Thanks for your Time and Help!
  • Posted 22 Mar 2024 06:22
  • By Zoomlifts
  • joined 17 May'19 - 13 messages
Zoom Lifts
having trouble locating the proximity switch
  • Posted 10 Apr 2024 08:21
  • By hunter_metzker
  • joined 10 Apr'24 - 1 message
Hello All thanks for all your help We were able to get this fixed!
Was able to get a schematic found there was an extra wire add to the black wire on the 90 degree proxy sensor, I removed that wire and unit works as should.
Thanks again!
  • Posted 10 Apr 2024 03:09
  • By Zoomlifts
Zoom Lifts
Hi
Per below, if you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
Combilift has Technical support technicians across the world including in NC at the North America Headquarters, that can help.
You can also request access to our knowledgebase where you will find more information available. Hope you get sorted.
  • Posted 4 Apr 2024 19:38
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
BLey I found this morning that one of the wires were pulled out of the relay. i fix and repaired it. Now the front tires are over rotating passed 90 degrees. the 6 way valve never turns off.
thanks for your help!!
  • Posted 27 Mar 2024 22:17
  • By Zoomlifts
Zoom Lifts
Definitly should be running a plc board in the dash.
I was re reading your earlier responses and need clarification. When you said you checked the rear prox switches and both lights are on what do you mean. Only one prox switch on the rear should be lit up at a time.
And when your checking them are you turning the rear tire all the way to the 90 position touching the stop bolt to the frame, checking to see if it is being turned on and that the air gap is no larger then 8mm. (As well as checking to make sure the other 0 degree prox switch is Off)?
But if your correct and saying everything is good with the rear prox switches i would
Check relay 9 terminal 30 for 12v. If it has 12v jump to terminal 87 to bypass the relay and see if the change over valve (6port) operates.
If it doesnt its wiring or connector issue.
If it does operate check relay 9 terminals 85 and 86. One should have ground and the other should have 12v after the plc board has recieved a signal from the rear 90 prox switch and the directional lever is in the right or left position.
  • Posted 27 Mar 2024 11:04
  • By BLey
  • joined 31 Jul'20 - 59 messages
Bley, Engine is 3.0L PIS(GM) Date 10/2016
  • Posted 27 Mar 2024 00:40
  • By Zoomlifts
Zoom Lifts
What engine and date of manufacture. Relay or PLC truck.
Newer PLC trucks relay 9 controls the 6 port change over valve.
Power to pin 30 on relay 9 come from F4 20amp.
Pin 87 goes to the coil on 6port valve.
PLC board applys power to relay 9s coil either on 85 or 86. Cant remember. And the other is grounded. After it recieves the signal from the rear 90 prox.
If you have the owners manual for the unit I suggest you run through the PLC diag as its easy to confirm if the PLC can output and turn on the valve as well as confirm that its getting the signal from the prox switch.
  • Posted 23 Mar 2024 10:02
  • By BLey
does any one have a wire diagram that shows where the changeover valve gets its power from would be very helpful. I can add power after the rear tire stops moving and add 12v to the changeover valve and the wheels will move.
Thanks!
  • Posted 23 Mar 2024 05:44
  • By Zoomlifts
Zoom Lifts
Thanks,
I have swapped the rear proxy sensors with and other working unit that unit still works fine. and all relays test good.
  • Posted 23 Mar 2024 01:37
  • By Zoomlifts
Zoom Lifts
Hi,
The proxy sensors unfortunately do get impacted and as they are needed to control the movement to the alternative directional change, a loose or impacted one should always be checked for. When a truck ships new a spare one is provided in the cabin.
If I understand correctly when you put the directional level to right, the rear wheel turns to 90, (parallel with back plate), but the front wheels do not turn to 90 also. If this is the case then first check the rear wheel 90 proxy sensor has been activated. (When it activates it changes the oil supply in the 6 port to turn the front wheels to 90, until the front wheels reach the 90 proxy, then the cycle is complete.)
If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
  • Posted 22 Mar 2024 23:03
  • By Richard_Irwin
  • Monaghan, Ireland
Then try swapping some relays under the dashboard
  • Posted 22 Mar 2024 22:51
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
Light comes on , on both proximity switch when tire stops moving.
  • Posted 22 Mar 2024 22:49
  • By Zoomlifts
Zoom Lifts
Check the proximity switch on the rear tyre is being seen when the rear tyre stops moving.
  • Posted 22 Mar 2024 07:03
  • By andrew_k
UN Forklift FD35T-C2JB2
Enforcer FD50T-MMA
Sue Tomic Sue Tomic
