SJ 6832RT instant load on motor when switched to low range
I have a 2017 SJ6832RT that when you flip the switch to have the machine run in low range it instantly loads up the motor. The machine will still move but does not have the power to do anything other that move on flat ground. If you try to move it up it up hill it loads up the motor even more until in boggs down and dies. Any suggestions would be helpful.
  • Posted 9 Feb 2024 07:10
  • By Sherlock_Holmes
  • joined 9 Feb'24 - 1 message
  • Oregon, United States
Double check low speed valve and coil, speed be able to swap with another valve and coil, just verify in manual that the part numbers are the same
  • Posted 17 Mar 2024 09:58
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
