Jungheinrich Stacker Error 4214.11
Hi all,
The model year is 2019 and some time it shows error 4214.11 during lifting. I have noticed that this is particularly showing error when the forks taking load during the transfer from the first lifting mast to the next lifting mast and also after first lifting mast at any height.
  • Posted 4 Feb 2024 02:16
  • By Syed
  • joined 14 May'15 - 194 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
There is a possibility that you are lifting a heavy load. Or the weight sensor is damaged
  • Posted 9 Feb 2024 08:03
  • By pavel_y
  • joined 27 Jan'16 - 52 messages
  • Donetsk region, Ukraine
Specialized repair of electrical equipment warehouse. Repair of controllers and components
Check valve coils and connections, check height sensor(should be on top of the mast reading laser engraved marks on side lifting cylinder.
  • Posted 5 Feb 2024 04:28
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Noblelift
