code 03
Need to know what this code stands for? Have to turn key on and off several times to make it work.
  • Posted 11 Jan 2024 07:59
  • By JoeMar
  • joined 18 Oct'16 - 14 messages
forkliftstech@gmail DOT com
Thanks, I will check those out.
  • Posted 12 Jan 2024 05:31
  • By JoeMar
I believe that code is controller is seeing reverse switch on start up check for welded or miss adjusted reverse switch check for short on wire p5 of controller if you fond nothing wrong possible controller problem.
  • Posted 12 Jan 2024 02:04
  • By Scott_
Scott
JCB 533-105
Enforcer FLBAXT25
