Nox sensor codes
So have a government truck here L006 and it is throwing a 3223-12 code. that is for Pre Nox sensor. all sensors have been changed out and the code keeps returning after an hour or so. i have 4 trucks all at the same location doing the same thing.
any help would be great
thanks
  • Posted 6 Jan 2024 07:15
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Roy,
At the connector going to the HEGO, pin 1 is battery voltage with key on. No voltage, need to check fuse 10. Next, disconnect battery and check pins 2 and 5 resistance to battery negative cable, should reads less than 1 ohm. If resistance is high or out of range, need to check harness. Connect battery and check pins 3 to battery negative, then pin 4 to battery negative, both should read about 2.5 volts. If one is a little less or a little more that is OK. Both together need to be about 4.5 volts. Again, should they not read correctly, check harness. Last, check ohm reading between pins 3 and 4, looking for 60 ohms. All checks are made where the NOX sensor connects to the harness. Good Luck
  • Posted 12 Mar 2024 02:59
  • By Fishmech
  • Virginia, United States
I have same model doing that. Has been going on a year now. Have no idea, as soon as I turn it off it clears and can't trouble shoot what isn't there
  • Posted 8 Mar 2024 13:17
  • By Roy_Baumeister
  • joined 9 Aug'23 - 9 messages
  • British Columbia, Canada
I can see more specifically that code is for pre nox sensor heater error. Check battery > fuses > wiring. Good luck.
  • Posted 9 Jan 2024 00:46
  • By James_Brand
  • joined 13 Nov'23 - 4 messages
  • United Kingdom
VETTER Industrie GmbH
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Kalmar DCE160-9
USD8,350
Kalmar DCE160-9
