No Functions
I am hoping somebody can help me. I have a JLG 4069LE serial number 200171876. It was working normally until it was turning left and shut down. Now when it is turned on from the base I am getting a flash code 6 and when i turn it on in the platform position I am getting a flash code 9. The contactor assy has been replaced with no change. I have no functions at all, even auxilary. Any pointers would be greatly appreciated. Thank You in advance. Shane
  • Posted 9 Dec 2023 12:36
  • By shaner
  • joined 1 Mar'11 - 29 messages
  • British Columbia, Canada
if it faults when you turn left then i would check the wiring in the harness's on the frame and the wheels (if its 4wd). check all the connectors in the harness and also at the controller. when you turn the wheels something is moving and breaking a connection. look for any damage to the wiring etc.
  • Posted 14 Dec 2023 17:44
https://cdn-oskdam.scdn6.secure.raxcdn.com/dmm3bwsv3/100113_0_11_14_44_0_42b22f99-9e5b-4a9f-b81f-281e0ecc2638_True_.pdf
Download the manual. Then if you can't get an analyzer. Count flashes...should be one set then a second...that will tell you like 1 flash short pause then 2 flashes a 1-2 code
Hope this helps
  • Posted 14 Dec 2023 06:31
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Taylor T650L
