Loses Travel
Periodically while changing directions or stopping and starting forward or reverse again, a brief message appears on the display "center hand control" and then a beep occurs, a wrench appears on the display and travel is disabled. In order to get travel again you have to turn the key off and recycle the start-up.
Any ideas!
  • Posted 14 Nov 2023 08:14
  • By DaveSr
  • joined 2 Mar'12 - 53 messages
Never too old or too experienced to learn more.
Thanks!
  • Posted 16 Nov 2023 00:24
  • By DaveSr
The analyzer menu is built into the truck. To get to it use the access 1 screen down arrow to select "Service" then press the right arrow. Enter the service password. The first menu should be the analyzer, the service manual has a detailed list of the analyzer menus in the Access 123 section.
To see previous codes, re key the truck to get out of the service menu. Then use the down arrow to get to "events" then use the right arrow to enter that menu. It will show the last 12 codes present.
  • Posted 15 Nov 2023 23:54
  • Modified 15 Nov 2023 23:56 by poster
  • By DyslexicNerd_01
  • Wisconsin, United States
I did not notice a code, and where do I get one of these analyzers, and how expensive are they? And lastly where does it plug in?
Thanks!
  • Posted 15 Nov 2023 08:42
  • By DaveSr
Check the code. Depending on code, then proceed with analyzer to see what component/s is failing.
  • Posted 15 Nov 2023 03:47
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Sue Tomic Sue Tomic
Terberg YT222
Toyota 02-2TD20
Terberg YT222
Toyota 02-2TD20
