Timing before removing head
Started my first repair on a 4G63 in a Cat GC25K. Been doing overhauls on tractors and industrial equipment for 30+ years. The unit has no compression on 3 & 4. So we are gonna pull the head and go from there. I have researched and can't find much on timing up before I pull the head. We've only worked on domestics (farmall, IH, JD, Oliver etc) and this is my first OHC! This unit may require a full OH but head is coming off first per client request then pull engine if required. Any help on timing specs would be great. I see a dot on the single belt pulley that drives the dual cams but I can't find anything else. Also looks like the distributor is bolted on with the intake manifold so is there an additional step there? Thanks in advance
  • Posted 24 Sep 2023 20:55
  • By Appleweld
  • joined 23 Sep'23 - 2 messages
  • Kentucky, United States
AA
Terberg RT403
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Oxford Ct, United States
Esie Cortez Esie Cortez
