Not moving or raising forks but has full charge
Ran into an issue recently with my electric CAT forklift. Used it all morning then plugged it in to charge. I came back and it had a full charge but it would not move in forward or reverse. The forks would not raise or lower either but they would tilt forward and backward and go left/right. Also when I turn the forklift on everything on the panel lights up correctly showing the charge and all that but a constant beeping noise now sounds that had not previously been sounding off.
Any tips or ideas?
  • Posted 31 Aug 2023 06:27
  • By James_Champion
  • joined 31 Aug'23 - 1 message
James Champion
if there are any errors/faults they should be showing up on the dash display by fault code and maybe accompanied with an associated icon.
when starting the lift make sure the park brake is set, you are on the seat and the seat belt fastened, maybe even depress the brake pedal while turning on.
By your description that there are no main functions, only accessory functions are working it should be showing a fault code when you try to operate it.
  • Posted 31 Aug 2023 23:51
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
Philadelphia, United States
Dayton OH/Cincinnati OH, United States
Prospect CT, United States
Taylor TX175
New - Sale & Hire
Terberg RT403
Taylor TX175
New - Sale & Hire
Terberg RT403
October 8-10, 2025 - Lucca, Italy
June 17-20, 2026 - Bangkok Thailand, Thailand
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1250 - 2 October 2025
