DTC 520304-1
Hey all. Have access to Yale service manual and this code isn't listed. Can anyone tell me what it's for. It has disabled the truck
Thanks in advance
Roy
  • Posted 9 Aug 2023 06:24
  • By Roy_Baumeister
  • joined 9 Aug'23 - 9 messages
  • British Columbia, Canada
Thanks. I have service passwords and calibrate every transmission service/1000 hrs.
  • Posted 7 Sep 2023 23:19
  • By Roy_Baumeister
Roy
Also the transmission should be recalibrated every 2000 to 3000 hours or anytime the transmission is serviced. This will calibrate the clutch packs. But will have to be done by a Hyster certified technician and use of a laptop or Service Password.
  • Posted 7 Sep 2023 23:02
  • By Jessy_Gomez
  • joined 30 Nov'22 - 12 messages
JJG
Appreciate the reply. 5000 hour truck with fluid and filter changed every 1000 hours. I will monitor. So far error has not reoccurred.
  • Posted 6 Sep 2023 02:40
  • By Roy_Baumeister
Roy.
Your forward clutch pressure reading is below normal operating range, most severe. Need to verify transmission fluid is at level. Check trans filter to see when it was last changed. If the filter is solid black it has never been changed. Could have a failed pressure relief valve, but would expect additional codes. Depending on hours and age, operations of lift, clutch pack could be worn out. Have known the transmission harness to fail, possible failed connection. Good Luck
  • Posted 6 Sep 2023 01:29
  • By Fishmech
  • Virginia, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 12-1200B
Lift Technologies Inc.
