toyota 7fgu(15?)
I Have a toyota 7 series that will not stay running. as soon as you release the key it dies.... if you hold the key in and unplug the starter coil, the truck will appear to idle just fine. I Have checked the "usual" distributor connector has 12 volts to it. the single wire oil switch (by the fuse box) has 12v to ground. I swapped as many relays, between this truck and another just like it.
Oh Yeah, This truck died right after a " tune up" plugs/wire/cap/rotor etc.... HELP!!!
  • Posted 25 Nov 2008 07:59
  • By NoBody
  • joined 21 Mar'08 - 11 messages
  • Virginia, United States
A true friend knows what it is!
Thank you all for your answers, but alas... The customer shipped it off to another division... (it ain't there problem, no more). I appreciate the quick response as usual guys!
  • Posted 2 Dec 2008 09:07
  • By NoBody
Run 12 v to coil.Start truck if it runs Check wire to coil.Some have 2.1 hot in start 2 hot at run.Check all connections between switch and coil for bad current flow
  • Posted 25 Nov 2008 22:46
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
does it have an external resistor on the coil?
is this a truck built since 2004 (CARB?)
have you checked to make sure there is a good ground to the ignition sensor pickup in the distrib?
  • Posted 25 Nov 2008 21:50
It does sound that way, I agree. However I did take a known good one and try it... no change. The relays energize and the dash lights up in the run position.
  • Posted 25 Nov 2008 09:17
  • By NoBody
Sounds like a bad key switch to me and probably has nothing to do with your recent tune up.
  • Posted 25 Nov 2008 08:37
  • By duodeluxe
  • United States
duodeluxe
TCM FD115-3
Komatsu FD25T17
