Fault Codes 9-2, and 9-3
I have a scissor lift that will not work at the platform controls except left and right turn. No drive or lift. It will lift at Ground controls. Plugging in the Analyzer gives me a code of 9-2 and 9-3 with no clear explanation. Does not list these codes in the service manual. Having a 9 to start the codes makes me believe its in the JLG Smart System. Anyone familiar with these codes?
Serial Number: 0200029933 Model Number: 2646E
  • Posted 5 May 2023 10:50
  • By ChrisM
  • joined 5 May'23 - 7 messages
  • Michigan, United States
Chris M
Thanks for your help. I'll make the call.
  • Posted 7 May 2023 00:53
  • By ChrisM
Chris M
yeah i did some more digging and did find that smart system supplement with those codes in it. sure, broken wires at that connector would explain the 9-3 code. The eeprom fault is a different story though, could have happened when those wires broke, could have shorted out on the frame and corrupted the eeprom. I'm not totally sure if they can be flashed in the field, the handset does not have that capability and i do not know of any laptop program for these units, JLG only offers that handset as far as i know. Again, you may still have to consult JLG engineering on that one, either they will say to replace the controller or send it in to be reprogrammed. Only they can answer that one i'm afraid.
  • Posted 6 May 2023 12:53
I actually found the book on the JLG website. Fixed 9-3 (mux stream not being updated) Broken wires at the platform control box connector underneath. 9-2 is an EEprom fault. I'm thinking that's what you said of the controller. Have to study up on the EEprom. Any more info would be appreciated.
  • Posted 6 May 2023 12:36
  • By ChrisM
Chris M
chris,
you may need to call jlg engineering for help on this since it is not listed in the fault code list.
the 9 indicates it is a hardware related issue it just isn't something listed.
This may be a controller failure but i'd let JLG confirm that before you go and buy one.
  • Posted 6 May 2023 12:21
Taylor X550M
Terberg YT220
