transmission problem
hello there friends... i need some help with heli cpcd80 transmission... recently i rebuild the transmission and looks fine, 3 hours on the job and the transmission slip completely.... i have done a main line pressure test, and the pressure manometer stay in 200 psi hot...
with cold oil temp the pressure readings is 400 psi.
please help
  • Posted 3 May 2023 03:44
  • By Jorge_Armas
  • joined 3 May'23 - 1 message
  • Venezuela, Bolivarian Republic Of
Have you tried contacting any forklift transmission rebuilders if not that might be a good idea.
  • Posted 18 May 2023 03:57
  • By jason_g
  • joined 18 Apr'11 - 31 messages
  • Illinois, United States
