Some help please !
This is an old scr model. It looks like it was made with some parts from Cesab. It has the typical 3 scr type circuit. A loose part in the machine fell against the choke coils and destroyed it taking out the turnoff scr and a resistor in the controller board. An attempt was made to make a coil to replace the choke but I have no way of knowing if it is anywhere near correct. The scr and resistor were replaced also.
The symptoms I have at the moment is the fwd or reverse contactors close but when the accelerator is pressed there is a "backfire", the contactors drop out and the wheels move a bit.
If I disconect the kathode of the turnoff scr from the snubber board there is a very slow commutation with little power.
I've been over and checked everything I can think of. The controller card is Cesab 104 FM/I.
Grateful for any advice
  • Posted 24 Apr 2023 23:32
  • By JonoG
  • joined 15 Feb'19 - 77 messages
  • Uruguay
Jonathan Gill
