Code 524261-11 /524261-2 - H80FT N005V04364F
Hyster H80FT N005V04364F
I need a little help please.
Code
524261-11 ECU 5-Volt Sensor Supply A Data Invalid, Cause Unknown
524261-2 ECU 5-Volt Sensor Supply A Incorrect Output
we replaced ECU and Throttle sensor with new hyster parts
We have done all trouble shooting we can do. We have removed covers on wire harness found no break or melted wire. Installed new ECU and had original ECU sent to Flight Systems they could not see any wrong. This unit Starts, runs and goes in to gear, has no throttle.
Thanks!
  • Posted 4 Apr 2023 23:08
  • Modified 12 Apr 2023 05:50 by poster
  • By Zoomlifts
  • joined 17 May'19 - 13 messages
Zoom Lifts
Zoom,
Will need to verify if the throttle sensor at the pedal is working. There are two channels, A and B. A will be twice the voltage of B. Also, has anyone removed the harness? I believe there are to connectors that are about identical between a sensor and the TPS. You will need to inspect the connectors and verify the correct connector is in the correct location. Good Luck.
  • Posted 31 May 2023 04:38
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Aichi RX07B
Sue Tomic Sue Tomic
USD6,396
Aichi RX07B
