Code 330
Can anyone shine some light on code 330? Following the manuals steps, I'm at the replace motor step now. Anyone encountered this code b4?
  • Posted 20 Jan 2023 04:24
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Event Code 330
ACCESS 3™ TRACTION MOTOR ENCODER
(ECR1) COUNT ISSUE
The traction function is disabled.
Note: If the lift truck logs Event Code 330 with Event
Code 366, 367, or 377, then refer to Event Code 366,
367, or 377 first.
Step 1: Turn off the lift truck. Then turn on the lift truck
again.
* If: The lift truck logs Event Code 330 again.
- Then continue to Step 2.
Step 2: Turn off the lift truck. Check the continuity of
the wires from ACCESS 3™ CA401-5 to ECR1 CA630-
3 (Channel A) and from CA401-6 to ECR1 CA630-4
(Channel B). Look for short circuits or broken wires.
* If: There is damage to the wires or connectors.
- Then make the necessary repairs or replacements.
* If: There is no damage to the wires or connectors.
- Then continue to Step 3.
Step 3: Turn on the lift truck. Measure the voltage to
ECR1 at CA630-1 and CA630-2.
? The correct voltage = 12 V.
* If: The voltage = 12 V.
- Then replace ECR1. If the event code continues,
then replace M1.
* If: The voltage ? 12 V.
- Then replace the wires or connections to ECR1.
  • Posted 20 Jan 2023 19:27
  • By Fanis
  • joined 8 Dec'22 - 9 messages
  • Greece
fanis
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Terberg YT222
