Red flickering LED when trying to charge batteries
Unit stopped charging, found out all 4 batteries were very low on water. Added distilled water. Now when plugged into AC power to charge, the led that is normally green during the charging cycle is flickering red/orange. All the connections are clean and tight.
I read a posting that says the charger wont work if the batts are too low. Is this true? I was thinking of calling local auto parts to see if they can charge/test these 6v batts, thoughts?
  • Posted 9 Nov 2022 07:35
  • By Rey_Garza
  • joined 9 Nov'22 - 1 message
what kind of battery pack is it a harris ?? if so you can take a 12 volt charger and link them inline with 2 batteries at a time and get them to charge for a bit. just make sure you follow the cables to see what battery is linked to make 12 volts
  • Posted 17 Nov 2022 23:32
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Aichi SR18A
Aichi RX07B
