Code:3701-0 Excessive Particulate Matter Level-5
Good day,
Operator mistakenly filled diesel into the DEF tank and received a trouble code.
The DPF itself has been removed and cleaned with water.
The 3701-15 was cleared with on-board equipment, but the 3701-0 requires the "Hyster pc service tool".
The engine is running at 1200 rpm (limp mode) because code 3701-0 is displayed.
The engine rpm only goes up to 12.00 rpm (limp mode).
I am planning to purchase the "Hyster pc Service Tool" or an alternative generic scan tool, can you recommend a good scan tool?
Compatible Vehicle : Hyster
Model : H155FT
Serial No : L006V02026R
Year : 2017
Engine : KUBOTA 3.8L
Display of vehicle DTC(Diagnosis Trouble Code) and data acquisition.
Clear DTC:3701-0
  • Posted 23 Sep 2022 11:13
  • By TenTen
  • joined 23 Sep'22 - 7 messages
  • Japan
Thank you, I have already got the PC Scan Tool software.
  • Posted 20 Aug 2025 07:32
  • By TenTen
  • Japan
If you need we have Yale Hyster PC Service Tool 5.5
  • Posted 19 Aug 2025 21:01
  • By Dil_Era
  • joined 30 Jun'25 - 35 messages
dilshanrandeep@gmail.com
Yes, it's resolved.
I finally connected the Hyster PC Scan Tool and cleared the code.
As a result, the forklift is operating smoothly.
  • Posted 25 Sep 2023 16:58
  • By TenTen
  • Japan
pls have you been able to solve your problem ?
  • Posted 8 Apr 2023 00:46
  • By northstar
  • joined 16 Jun'17 - 91 messages
  • accra, Ghana
Yes, it is equipped with a Kubota engine.
The Kubota dealer at my location (Japan) refused to respond.
I am struggling because there is no Hyster dealer in Japan.
I will try to contact Hyster dealer in the US.
I am hoping to be able to clear the code by mailing the ECM only.
Thank you.
  • Posted 11 Mar 2023 13:28
  • By TenTen
  • Japan
That was a long shot I know. Because it is a Kubota engine, you are correct. The dealer will need to connect. Should you find a Cummins engine in a lift, the on-site program from Cummins can be used. Good Luck
  • Posted 11 Mar 2023 07:31
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
I tried clearing the codes by way of removing the battery terminals but could not erase the codes.
They need to be erased by a Hyster dealer using a PC service tool.
  • Posted 10 Mar 2023 16:01
  • By TenTen
  • Japan
Try this to clear code long enough to initiate DEF regen. Disconnect the positive cable and touch it to a ground. This should may clear all codes so that a regen is possible. Read through the operators manual so you know how to complete a parked regen. Good luck
  • Posted 1 Oct 2022 00:21
  • By garland_m
there is no tool or scan tool you can buy to connect into the hyster or yale service tools they are a dealer only item.
  • Posted 29 Sep 2022 01:49
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Deborah Baker Deborah Baker
TCM FD80Z7
TCM FD80Z7 1990
Ncn 110TH
Ncn 110TH 2015
