Yale serial number
I bought 2 old Yales at local auction and data tags are missing from both, where would the serial numbers be located, one is a 4-5000 lb pneumatic with a manual transmission and the other is a small cushion 3-4000 lb with an automatic, my guess is they are both 70's models. Thanks
  • Posted 8 Sep 2022 03:13
  • By Mitch_Egan
  • joined 7 Jan'21 - 6 messages
Mitch,
Try looking on the frame below the bolt on cab on the right side of the lift. I would also look on the left side of the frame. You may need to remove the floor board and look at each side of the frame. The serial number will start with either one or two letters followed by either 5 or 6 numbers. The letters designate the year and numbers for specifics on lift. Good Luck
  • Posted 1 Oct 2022 03:21
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Taylor TT300
Mitsubishi Logisnext FD25T5M
Taylor TT300
