Ignition issues
Key on. turn key to start. The test light at starter does not light up. Disconnect the 4" lead to starter. Retry with test light works everytime.
  • Posted 23 Aug 2022 09:29
  • By Gusstone
  • joined 17 Apr'20 - 25 messages
I believe it is a black relay in fuse box try starting truck and see if you can feel the relay clicking when trying to crank.
  • Posted 27 Aug 2022 05:58
  • By Scott_
Scott
Starter relay what it looks like
  • Posted 26 Aug 2022 08:01
  • By Gusstone
First make sure you have 12volts at battery when cranking it should not drop past approx 10volts check at battery and at cable at end of starter if good make sure you have good ground. if all checks out make sure truck is in neutral and emergency brake is on try to take jumper wire from positive of battery cable to small post of starter if truck starts you have a wiring problem.if not l would check starter there is a starter relay in fuse box but l have never had one go bad
  • Posted 26 Aug 2022 07:31
  • By Scott_
Scott
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
