lifting problem
I got an Linde L10 1172 year 2010 and shows E1 441 error, and is no lifting but is moving.
  • Posted 22 Aug 2022 17:32
  • By vanoss
  • joined 1 Nov'17 - 43 messages
  • Bihor, Romania
Thank you very much !!!
  • Posted 28 Aug 2022 13:51
  • By vanoss
  • Bihor, Romania
441 Higher force setpoint out of high-limit
LAC 441
Fault description
Conditions of occurrence
Motor power required according to accelerator position is above the upper limit value
Error was not detected by main processor
Result
Lifting, lowering and traction deactivated (PWM lifting 0%, valves closed,safety relay opened)
Possible causes
Voltage displacements at the inputs
Potentiometer not calibrated or defective
Check motor connections
  • Posted 27 Aug 2022 17:52
  • By michel_v
  • noord holland, Netherlands
Hi,
You can be more explicit please?
What should i check?
Thank you in advice.
  • Posted 23 Aug 2022 01:46
  • By vanoss
  • Bihor, Romania
  • Posted 23 Aug 2022 01:43
  • By michel_v
Taylor TT300
Linde C4230TL5
