Locked up motor , torque converter stuck in trans , what have I broken
I picked up a Clark GPS30 , the motor is locked up , so therefore I could not unbolt the torque converter from the flywheel, Well after lots of prying the converter is out , there is a gear on the end of it , that looks like it was driving a chain. I have seen a broken bearing cage , roller bearing , not ball bearing. and took the seal out too.What have I done , I was thinking it would be like a car , and the converter would just slide out , but no. Do I have to remove the trans to fix it ?
Thanks Daniel Cross
  • Posted 16 May 2022 13:42
  • By Daniel_Cross
  • joined 6 Nov'20 - 8 messages
  • Virginia, United States
Yes, you will end up pulling the transaxle assy. All comes out the front. Mast off. Be aware, with mast off and trans/diff assembly out, the truck will tip back. The counterweight will need supported. I recommend getting the service manual for that machine. It breaks down the specific trans. Or at least get the parts breakdowns. That should be the HR600 Transmission.
  • Posted 19 May 2022 05:00
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
Columbus, United States
Oxford Ct, United States
Libiao Robotics
