LIFT GOES UP 6' AND STOPS
SKYJACK SJIII 4632
This darn machine will go only up about 82" (ground to floor) and STOP, same place every time. I am electrician of 31yrs, and I am beginning to think I gotta go back to trade-school!!!! This is driving me crazy!
It drives fine, steers fine, DOWN is fine.......but all of a sudden it stops at 82" when given an UP command!
Machine is level.....totally level. Batteries are full. Lift is empty (no load). Oil reservoir full. Does this with platform and base controls, either or, same problem.
When I manually rotate the lobe (at the safety limit switches on the rear-side scissor X frame members) that actuates the limit switches, it permits me more distance for UP travel. I know I can't rotate these lobes to suit my interests as they've been set for a reason.
Does anyone know why a lift would go up and stop when one of those safety limit switches is actuated?
  • Posted 27 Apr 2022 06:26
  • By Wayne_Layman
  • joined 27 Apr'22 - 1 message
  • Alberta, Canada
Pothole switches aren't closing, look at the springs in the back of the side doors and verify coming all the way down. If they are open the doors and look by where those springs activate a switch on each side, one of those switches aren't closing
  • Posted 13 Jun 2023 14:18
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
GemOne
JCB 533-105
Kalmar DRF450-70C5XS
