Error code E55 after removing mast.
Our mechanics removed the mast from the reachtruck and re-set it for maintenance.
Now is shows error E55 and it's in super slow mode.
We checked every sensor but everything seems to be working fine.
I suspect we need to reset or calibrate but i have no idea how to and i don't know any service codes or passwords. Any ideas?
  • Posted 27 Jan 2022 05:46
  • By Toby_Sangen
  • joined 27 Jan'22 - 1 message
  • Netherlands
Toby
you need to calibrate all setting, drive and hystraulics first press s for service then press 3 for atlet service on the display shows 7 digit # press 0002468 the key board has 2 arrows for up or down for options, perss enter then go to drive test- then go to calibrate acceleration perss enter, press accelerator pedal alway down hold and press any key ones then press enter agian then press arrrow go to calibrate brake repeat, same steps as you did for the accelerator, then press enter go to calibrate drive wheel, repeat same steps then go back to drive tested use arrow go to hydraulics press enter go to calibrate lift levers press enter start with lift lever, press up n down- press enter and repeat the same for all levers if the calibration fails, you will see the massage on the display if the happens, start from the beginning if you loese track press H that will take you back one step, if you want to get out of the system press enter like 4 to 5 times then log on the lift truck and try to drive and tested the hydraulics, good luck!
  • Posted 16 Feb 2022 01:11
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Dear sir
I did the same thing and same issue happened
Pls let me know how to solve it
  • Posted 15 Feb 2022 19:00
  • By marantonious
  • joined 19 Jun'18 - 48 messages
  • kuwait, Kuwait
Marc ANTONIOUS
UN Forklift FGL25T
Toyota 8FD45
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
