Battery connection
I purchased a W40z B218 lift. No batteries and the owner gave me a diagram. Purchased 4 batteries that will work but when I check the voltage between batteries it shows 12 volts. It says it's a 24v lift. The batteries are equal to US Battery 1800xC2 6 volt. I saw the lift work but the seller wanted the batteries for another unit because they were new. The drawing looks like a combo of serial and parallel connections.
Thanks
  • Posted 19 Jan 2022 05:49
  • By CharlieT
  • joined 19 Jan'22 - 1 message
I read your post l never seen this truck battery's hooked pallets and series the truck is wired 24 volts with 4 6volt deep cell battery's series to make 24 volts to the end of the run also make sure if has eternal battery charger that you hook it up or controller will not turn on hope this helps
  • Posted 21 Jan 2022 01:50
  • By Scott_
Scott
Airman ENCL045
Terberg YT220
Airman ENCL045
Terberg YT220
Sue Tomic Sue Tomic
